jw-lighting Posted July 3, 2015 Report Share Posted July 3, 2015 Hi, i want to trigger playbacks controlling only non-intensity parameters using a midi lauchpad (no need for a fader...). MIDI is already supported by the FLX, but most launchpads only have a usb port. Does the FLX support MIDI over USB ? Do you have other ideas to trigger playbacks by something similar? Regards Jan Quote Link to comment Share on other sites More sharing options...
jonnyweston Posted July 7, 2015 Report Share Posted July 7, 2015 Its a very prominent question... a question that I have also had in my head too.Something like : Akai MPD26 Korg PadKontrol will have Midi out on 5pin din style cable. I know that a friend of mine has successfully patched an AKAI to his Avolite Quartz, so see no reason why it shouldn't work on an FLX. Hopefully these would be solutions that might suit your requirement.Thanks, Jonny Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted July 7, 2015 Report Share Posted July 7, 2015 Currently, we only support MIDI over the 5pin din cable, not over USB. Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
