Hello
Is there an easy way to offset an effect across multiple fixtures without having to manually select each one and then choose an offset?
For example if I have 6 LEDs and want a rainbow effect, (i think) I have to manually select them one by one and vary the offset otherwise they all do the rainbow effect at the same time.
Rob
One easy way is to record your fixtures to a group, then you can apply the effect to the group and use the group offset. I'm not in front of the console, but from the top of my head that should give you the desired result.
Hi Rob, you can just hold SHIFT and move the offset encoder to "fan" the offset across all the selected fixtures. This will "fan first" which means from the first fixture, but you can change this by pressing SETUP and EFFECT together to get various options
Jon Hole
