NickTaylor Posted June 25, 2015 Report Posted June 25, 2015 I am working on a show with a friend who is actually doing the programming. Yesterday morning we had worked our way to the end of a fairly complicated show and thought it was just tweaking time. However I got a call to hear that chunks of cues had gone. The cues left seem to be ones that were adjusted at the end of play yesterday. Sadly there was no stored recovery backup so a lot of Act One has had to be redone. I can imaging the odd cue going but not chunks. Has anyone else had this problem? Quote
keredyelesob Posted June 26, 2015 Report Posted June 26, 2015 Hi I have never had this happen to me but can i ask what version of the software are you running? is it entire cues or parts of cues? have the cues gone completely are are the positions still in the stack? (1,2,3,4..... or is it more 1,3,4....) what mode are you running in (tracking, none tracking. smart tag, no smart tag)? last question, may be a silly one but did you run any of the cues after you finished to see if they recorded correctly? did the cues mess up after turning the console off? Quote
