Lamp207 Posted June 23, 2015 Report Posted June 23, 2015 I have had several occasions where I am running the venue universe on an sACN network. What I would like to know if it is possible to run the network and also have the remote working too? I run the sACN network straight from the Cat5 line into the desk. But this stops me from plugging in the wireless router. Does anyone know a way round this? Am I able to plug the sCAN Cat5 line into the router to? Would this work? Also, Is there a way to install a master beat or effect speed fader to control the speed of multiple chases? Thanks. Quote
Jon Hole Posted June 26, 2015 Report Posted June 26, 2015 What I would like to know if it is possible to run the network and also have the remote working too? ... Am I able to plug the sCAN Cat5 line into the router to? Would this work? Yes, there's no reason you can't do this - ZerOS will give each one a separate IP address. I'd advise not using a basic "cheap consumer wireless router" if you're going to be running something as crucial as sACN traffic through it - it's worth spending a little more and getting a decent router designed to be used within an entertainment setting. Is there a way to install a master beat or effect speed fader to control the speed of multiple chases? Not currently - you can create a "Speed Override" fader which can increase or decrease the speed of all the chases and effects, as a proportion of whatever they are currently at, but not an overall "beat" / "tap tempo"... yet... Quote Jon Hole linkedin.com/in/jonhole
