daniloT Posted June 21, 2015 Report Posted June 21, 2015 I want to know how to record a chase on a sub or udk or one fader/chase? whiwh key button to load chase in manuel mode?thank you for your answers. Quote
Jon Hole Posted June 26, 2015 Report Posted June 26, 2015 Hi, To make a chase on ORB XF, you need to use a Cue Stack. These can be set to the bottom 20 faders using the "Fader Function" button. Record each step of the chase as a separate cue. You then choose "Stack Setup" (or hold SETUP and press the fader's flash button), choose "chase" in the window that popups, and then choose "Turn into chase". Quote Jon Hole linkedin.com/in/jonhole
sparkies Posted December 4, 2015 Report Posted December 4, 2015 Hi, To make a chase on ORB XF, you need to use a Cue Stack. These can be set to the bottom 20 faders using the "Fader Function" button. Record each step of the chase as a separate cue. You then choose "Stack Setup" (or hold SETUP and press the fader's flash button), choose "chase" in the window that popups, and then choose "Turn into chase". I am having a similar problem. I have it in a stack and changed it into a chase how do I record this into one of the subs on the bottom row? Quote
sparkies Posted December 4, 2015 Report Posted December 4, 2015 Ah, never mind have worked it out and also had to change to highest takes pres Quote
