timeofsilence Posted June 18, 2015 Report Share Posted June 18, 2015 I took the leap from a Fat Frog to a Frog 2. It arrived yesterday. While setting it up I came across a few issues, one is that the power supply is making a high pitched squealing sound. It gets pretty warm too. I'm not sure if this is normal or not. Also, I have a mouse plugged in to the PS2 mouse port and it doesn't seem to be working. I plugged a trackball in to one of the USB ports and it only worked intermittently. Any thoughts on this would be greatly appreciated. For what its worth, the desk is still on OS4 I believe. I tried updated with a thumb drive last night to no avail. I will try the CD version today. Quote Link to comment Share on other sites More sharing options...
iank99 Posted June 19, 2015 Report Share Posted June 19, 2015 Is it actually a Frog 2 PSU? The Frog 2 variant has a switch on the PSU case and (from memory) gives a higher current. Your Frog 2 would probably start up with a Frog PSU but it might well run warm and the USB hub might not have enough current to drive peripherals. Quote Ian Knight aka The Service Guy - www.serviceguy.co.uk Link to comment Share on other sites More sharing options...
