JB97 Posted June 9, 2015 Report Posted June 9, 2015 Hi, At school today we had lights on and then our whole second bar stopped working. I believe we have a chilli inductive, and we use a Jester ML 24 to operate the lights. We could smell burning both near the lights and in the lighting box. I believe it is an issue with the dimmer but I have no idea. Any thoughts? (Just for record this was reported and a qualified electrician will be coming in to sort out the issue) Thanks, James Quote
Jon Hole Posted June 9, 2015 Report Posted June 9, 2015 Hi James, With anything like this, advice would always be to get someone experienced and qualified to take a look at the problem, which it sounds like you're doing, so I'd leave it to them :-) Jon Quote Jon Hole linkedin.com/in/jonhole
JB97 Posted June 9, 2015 Author Report Posted June 9, 2015 On 6/9/2015 at 11:02 AM, Jon Hole said: With anything like this, advice would always be to get someone experienced and qualified to take a look at the problem, which it sounds like you're doing, so I'd leave it to them :-) Yeah, I wouldn't try to fix the problem my self, I just wondered what could have caused the issue that's all :-) Quote
KWR88 Posted June 9, 2015 Report Posted June 9, 2015 If you have not done so already I would advise you isolate the dimmer until you have had it assessed. Continuing to use this if there is a problem can result in more serious issue occurring. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com
JB97 Posted June 9, 2015 Author Report Posted June 9, 2015 On 6/9/2015 at 4:48 PM, KWR88 said: If you have not done so already I would advise you isolate the dimmer until you have had it assessed. Continuing to use this if there is a problem can result in more serious issue occurring. Yeah, when the lights went out, I went up to the desk, noticed the burning smell in the box at the same time as they noticed the burning smell in the theatre itself and I shut off the mains power to the dimmer I just really want to know the cause Quote
