JB97 Posted June 9, 2015 Report Share Posted June 9, 2015 Hi, At school today we had lights on and then our whole second bar stopped working. I believe we have a chilli inductive, and we use a Jester ML 24 to operate the lights. We could smell burning both near the lights and in the lighting box. I believe it is an issue with the dimmer but I have no idea. Any thoughts? (Just for record this was reported and a qualified electrician will be coming in to sort out the issue) Thanks, James Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted June 9, 2015 Report Share Posted June 9, 2015 Hi James, With anything like this, advice would always be to get someone experienced and qualified to take a look at the problem, which it sounds like you're doing, so I'd leave it to them :-) Jon Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
JB97 Posted June 9, 2015 Author Report Share Posted June 9, 2015 With anything like this, advice would always be to get someone experienced and qualified to take a look at the problem, which it sounds like you're doing, so I'd leave it to them :-) Yeah, I wouldn't try to fix the problem my self, I just wondered what could have caused the issue that's all :-) Quote Link to comment Share on other sites More sharing options...
KWR88 Posted June 9, 2015 Report Share Posted June 9, 2015 If you have not done so already I would advise you isolate the dimmer until you have had it assessed. Continuing to use this if there is a problem can result in more serious issue occurring. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com Link to comment Share on other sites More sharing options...
JB97 Posted June 9, 2015 Author Report Share Posted June 9, 2015 If you have not done so already I would advise you isolate the dimmer until you have had it assessed. Continuing to use this if there is a problem can result in more serious issue occurring. Yeah, when the lights went out, I went up to the desk, noticed the burning smell in the box at the same time as they noticed the burning smell in the theatre itself and I shut off the mains power to the dimmer I just really want to know the cause Quote Link to comment Share on other sites More sharing options...
