I have 2 Stairville MH-X25 LED heads but I am unable to control them on my Fat Frog. There is DMX signal and is running in 12 channel mode start address of 501 (only running 1 at the moment) but unable to control? Any ideas?
Can you tell us a bit more about what you see on the desk when you try to control the fixture? Did you build your own fixture profile (maybe you could attach to this topic)? Is the fixture assigned (yellow LED turned on in the button)? That fixture number patched to DMX 501 in the Fat Fog manual patch screen? Selected the fixture then see some attributes come up in the fixture LCDs - select Colour and see e.g. Red and Green and Blue? Dimmer at > 0%? Mode of the fixture the same as the fixture profile definition?
As 501 is right up at the end for a 12 channel fixture, maybe try it down the DMX address range a bit. Give 200 a try.
Kevin
Thanks for your reply. It seems the fixture reset back to 6 channel when powered on/off.I also changed DMX address to 200 as suggested so now have full control. Thanks for your help.
