ziglight Posted June 1, 2015 Report Posted June 1, 2015 the other topic is locked; so I create a new one here just for information (and this is not mentioned in the main-topic) : => when installing the new Beta version of Phantom ZerOS, this will replace (and erase) any older version of Phantom-ZerOS => this particular version (PhantomZerOS 7.8.2.16 MD Beta.zip) contains only the FLX editor, so there is no Solution and no ORB etc in it for people who just want to have a look onto it (and give a virtual try to the FLX...) but who are working usually with Orb or Solutions desks, be careful : it would be a good advice to install this Beta version in a "special place/folder" because otherwise you are loosing your ordinary PhantomZerOS version....
Jon Hole Posted June 1, 2015 Report Posted June 1, 2015 Hi Ziglight, Thanks for bringing this up. It is mentioned a couple of times in the release notes (once in the "general" section and once listed as ZOS-6085), but I've updated the original thread to make it much more obvious. Jon Hole linkedin.com/in/jonhole
ziglight Posted June 1, 2015 Author Report Posted June 1, 2015 thanks Jon in this case you can delete this topic here...
