b.a.m sound and lighting Posted May 29, 2015 Report Posted May 29, 2015 Hi I am having trouble with blending colours using sub masters, I have set up 4submaster: sub1 fixture intensity, sub2 red, sub3 green and sub4 blue. They work fine separately ie sub1+sub2 @ 100%, but if I add sub4 @100% to create purple it knocks off sub2 and leaves just blue All subs are set to HTP Is there anything I can do? Thank you in advance, Ben Quote
Jon Hole Posted May 29, 2015 Report Posted May 29, 2015 Hi Ben, Have a look at this article and see if it helps. If it doesn't, let us know and we'll go through it in a little more detail. http://www.zero88.com/support/index.php?/Knowledgebase/Article/View/585/ Jon Quote Jon Hole Global Product Manager, Systems and Control
b.a.m sound and lighting Posted May 30, 2015 Author Report Posted May 30, 2015 Thank you that's done the trick, I wasn't untagging Quote
