CTLX Posted May 19, 2015 Report Posted May 19, 2015 Hi I have an incoming show and they are bringing ADJ Inno Spot LED 150's with them. do you have a fixture setting for them for the Orb XF. file attached. Ta When you reply can you include the instructions on how to load onto the desk . Ta inno_spot_led.pdf Quote
Jon Hole Posted May 21, 2015 Report Posted May 21, 2015 Hi CTLX, Please find attached the fixture file for the Inno Spot LED. Inno Spot LED.ift Save the file on to a USB stick (don't hide it within any folders), plug it into the console, go into SETUP > Files > "Load User Fixtures". Choose the file, and click OK. This will then load them into the main library (you should get a popup saying "1 fixture type loaded") ready for you to patch them in the normal way. Quote Jon Hole Global Product Manager, Systems and Control
