quonky Posted May 15, 2015 Report Posted May 15, 2015 Hi, I'm looking for a fixture file for the above fixture if anyone can help? Here is the link to the manual: http://www.lantalighting.com/app/uploads/product_files/53/orion_link_v2_manual.pdf Many thanks, Jamie Quote
Jon Hole Posted May 15, 2015 Report Posted May 15, 2015 Hi Jamie, Which mode are you wanting to use? For 3ch mode, use the "RGB Dimmer" fixture within Standard Fixtures. For 4ch mode, use the "RGB+D" fixture within Standard Fixtures For the others, we'll need to make one for you. (Could you let us know which console you are using too, please) Quote Jon Hole linkedin.com/in/jonhole
quonky Posted May 18, 2015 Author Report Posted May 18, 2015 Hi Jon, Sorry for the lack of information. I was wanting to use them in 14ch mode, and the console is a Jester ML48. Many thanks for your help. Jamie Quote
quonky Posted May 19, 2015 Author Report Posted May 19, 2015 Sorry I made a mistake... it was 7ch mode, not 14 as I previously stated. My mistake! Jamie Quote
Jon Hole Posted May 21, 2015 Report Posted May 21, 2015 Here you go Jamie, Lanta Orion Link v2 7ch.iftFetching info... Quote Jon Hole linkedin.com/in/jonhole
