the leapfrog desks dont transmit midi they will only receive it.do you want to fire the go button with midi, or have the go button transmit midi?
Also i am not sure midi is transmitted/received over the network, i am sure someone else can confirm this though.
Hi,
Keredyelesob is correct - there's no way to do MIDI over the network on the LeapFrog 48 & 96.
You'll need the "SMPTE/MIDI/Remote/CAN PCB Upgrade Kit" in your LeapFrog to be able to recieve MIDI.
Regards
Jon
Jon Hole
Hi guys thanks for the replies just wondering if i could trigger the go button via a midi input from a sound desk able to output midi codes. What is the midi code to trigger the go button?
