the leapfrog desks dont transmit midi they will only receive it.do you want to fire the go button with midi, or have the go button transmit midi?
Also i am not sure midi is transmitted/received over the network, i am sure someone else can confirm this though.
Hi guys thanks for the replies just wondering if i could trigger the go button via a midi input from a sound desk able to output midi codes. What is the midi code to trigger the go button?
