hafashah Posted May 13, 2015 Report Posted May 13, 2015 good day to all , my solution keeps changing the clock every time I turn it off and comes bake in the next day , Any ideas ? Quote
keredyelesob Posted May 13, 2015 Report Posted May 13, 2015 I am no expert on this, but it sounds like it may be the internal battery that needs replacing. is the desk still recording shows ok as the battery will normally also effect this part of the desk at the same time. Quote
hafashah Posted May 13, 2015 Author Report Posted May 13, 2015 As far as I know the disk saves shows will , and runs them will , the disk is still new a doubt that it might be a battery thing ! Quote
Jon Hole Posted May 14, 2015 Report Posted May 14, 2015 If you go into SETUP > Desk Settings, you can see the date and time. Please could you set them both to the correct date and time, turn off the console, wait a while and then turn it back on. Please let me know both what you set the time/date to, and what it was when you turned back on the console. Many thanks Jon Quote Jon Hole linkedin.com/in/jonhole
hafashah Posted May 18, 2015 Author Report Posted May 18, 2015 Jon , So yes done that , worked all day on it , turned it off and today tune it back on there were 1 hour delay , the console was turned off 12 hours , I notes that after updating to the latest software , but I’m not sure Quote
