since the full manual is not yet published, we got some questions concerning playbacks and flx.
Imagine the following the situation:
Programmed Playback 1, Cue 1:
Some RGB-LED fixtures @ 100% intensity, Color: red
Programmed Playback 2, Cue1:
The exact same RGB-LED fixtures @ 100% intensity, Color: blue
Sliding Fader 1 up to full, running Playback 1, Cue 1 we see the fixtures light up in red light, just as we expect.
Now, touching Fader 2 und sliding up to full running Playback 2, Cue1, what is the result? (note: Fader 1 running Playback 1 Cue 1 is untouched at full output)
a ) HTP-merge of the output: red and blue combines to magenta
b ) LTP-merge of the output: the fixtures become blue
c ) Nothing happens since playback 1 is not released
d ) something different?
Thanks very much.
Best regards
Mathias
Hi Mathias,
If you do exactly what you've written, you'll get B - the fixture will become blue.
However, if you'd prefer A, this page shows you how to make RGB Submasters on our other ZerOS consoles.
http://www.zero88.com/support/index.php?/Knowledgebase/Article/View/585/
Doing it on FLX is very similar... the only slight difference is you go into the Stack Setting and change the "Fader Controls" there:
Hi Jon,
How do you handle the "untagging" of parameters on the FLX? Is it still holding "Clear" and touching the encoder? I thought I tried that when I was used it the other day, but if I recall it didn't seem to do anything? Perhaps there was another setting I needed to change?
