Cheesy79 Posted April 21, 2015 Report Posted April 21, 2015 Hi, I wanted to update my Frog2 console from OS 7.7.0 to 7.8.2.While checking the hardware, the software shows me that there is the wrong "flash storage size".There is a 1GB compact flash Card (CF) inside the desk.Can I change this card to an 2 or 4 GB card ? Best regards, Cheesy Quote
KWR88 Posted April 22, 2015 Report Posted April 22, 2015 Please PM on the address below. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com
frogfabi Posted July 27, 2016 Report Posted July 27, 2016 Hi, i have the same problem with Frog2 ( one USB Port on front ). Updating from Zeros 7.8.0 to 7.8.2.36 does not work. There is an error Message "incorrect flash size". The flash card size is 4GB. Best regards Andreas Quote
Jon Hole Posted July 28, 2016 Report Posted July 28, 2016 Hi Andreas, We're about to start beta testing 7.8.1, which brings the FLX software over to Solution and FROG2. I think this should solve your problem too. Would you mind giving it a go in a week or two? If so, can you email me on the address below, and when we're ready, I'll let you know. All the best, Jon Quote Jon Hole linkedin.com/in/jonhole
