Is there any option to set the chase speed of submasters on Solution seperate for each submaster, like on Jester series or ORB by pressing the flash button?
I've tried with the Phantom but didn't find any way to do it. This is the only reason i didnt buy a solution :(
You can set the chase speed within the sub master setup screen. (hold sown shift then press the flash button of the sub) this will set the speed on an individual bases.
If you want to set the speed on the fly (using beat or manual) then this will effect all of the subs as you use the step button and this effects all sub masters. I don't know of another way to set the speed on the fly.
