smcalister Posted April 5, 2015 Report Posted April 5, 2015 Hi, Was wondering if there is a way to create a step based effect to create for example a flicker effect Many Thanks Sandy McAlister Quote
Jon Hole Posted April 28, 2015 Report Posted April 28, 2015 Hi Sandy, You can select a new Cue Stack (STACK x ENTER) and then create several cues within this stack, each with the channel at a slightly different level. Now, click "Stack Setup" in the cue stack window, choose "Chase" in the window that opens, and then choose "Turn into Chase". You can then change "Chase Direction" to "random", and change the speeds etc within this window. Quote Jon Hole Global Product Manager, Systems and Control
smcalister Posted May 31, 2015 Author Report Posted May 31, 2015 Hi Jon Is there a way to create a custom effect so i dont have to swap cue stacks Many Thanks Sandy McAlister Quote
