  • 4 weeks later...
Hi Sandy,
You can select a new Cue Stack (STACK x ENTER) and then create several cues within this stack, each with the channel at a slightly different level. Now, click "Stack Setup" in the cue stack window, choose "Chase" in the window that opens, and then choose "Turn into Chase". You can then change "Chase Direction" to "random", and change the speeds etc within this window.
  • 1 month later...
