Shaunlsstudios Posted March 21, 2015 Report Posted March 21, 2015 I program movers on the sub master and then they have to have the intencaty turned up down manually how do I get it to do that automatically with the sub master Quote
Johnny Posted March 21, 2015 Report Posted March 21, 2015 I am not sure whether this will work but you can try the following: Enter SETUP, then go to DESK SETUP and then to SUBMASTER DEFAULTS. In SUBMASTER CONTROLS... activate POSITION. what kind of desk and ZerOS software are you using? Quote
keredyelesob Posted March 22, 2015 Report Posted March 22, 2015 Hi The intensity of the movers should be recorded as part of the sub. Are you clearing out the programmer before running the sub? If you have manually set the intensity to say 100% then this value will be held in the programmer and will take priority over subs Untill cleared. (This does however depend on the desk mode) Another thing that could be causing this is having the sm mode set to 'not release'. To access the sm settings you can hold down the setup button then press the flash button for the recorded sub. hope this helps. Quote
Jon Hole Posted April 2, 2015 Report Posted April 2, 2015 I'm guessing, as keredyelesob suggests, that this is because "0%" is in the programmer - and the "programmer always wins"! Pressing CLEAR twice will remove the 0's from the programmer, and the submaster's intensities will start working. Quote Jon Hole linkedin.com/in/jonhole
