jensorium Posted March 17, 2015 Report Share Posted March 17, 2015 Hey I am using a leapfrog 48 (without upgrade kit) and show cue system professional. (windows 7) Is there any possibility to run the next q by hitting the go button in show cue system? My idea was to send an dmx to the console but I can only run submaster via dmx in. and scs can't send dmx. Any idea? Artnet? I don't wanna hit two go buttons any longer or hit time cues. Thx Jens Quote Link to comment Share on other sites More sharing options...
mikeb Posted March 17, 2015 Report Share Posted March 17, 2015 Hi I also have SCS (Professional) and having looked at the SCS online comparisons it looks like you'd need SCS Professional Plus for DMX working - that said, sending of MIDI/RS232 from SCS is permitted in SCS Professional. The manual [ http://www.showcuesystems.com/scs11help/topics/prod-cc-dmx.htm ], also seems to read that the SCS software only works as DMX in; i.e. DMX sent from a console - " For DMX Control you need an Enttec 'DMX USB PRO'. (Note that the cheaper Enttec 'Open DMX USB' is not suitable as this only supports DMX Send, not DMX Receive.)" [ http://www.showcuesystems.com/scs11help/topics/scs-features.htm ] [ http://www.showcuesystems.com/scs11help/topics/prod-cc-dmx.htm ]. The last thing I found was "SCS also has the ability to activate cues from MIDI, RS232, DMX and Telnet input messages (provided you have the appropriate license level)" - note that DMX is striked out which reads that SCS is not able to send DMX Midi would seem an option but you would need the console upgrade kit fitted? I welcome any clarification on this Regards Mike Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted March 17, 2015 Report Share Posted March 17, 2015 Hi Both, Yes - the "proper" way to do this is via MIDI Show Control (MSC) using our SMPTE/MIDI/Remote/CAN PCB Upgrade Kit. List price is £108 / €135, and it's part number 12-123-99. If SCS was to allow DMX Out (I'm not too familiar with the software), you could potentially use DMX to trigger the submaster, and then run a macro on that submaster to press GO - but that really is a workaround rather than a nice solution. Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
jensorium Posted April 1, 2015 Author Report Share Posted April 1, 2015 Hey thanks for the replies. I didnt get an email about new replies, so sorry for my late reply. SCS doesnt support DMX out (in none of the levels), just MIDI. Yes i could buy this upgrade kit, but i need it just some weeks each year, so i would prefer a solution with an DMX interface. Running the Submaster with the Macro works perfect, so i have to find a solution to convert midi to DMX. Do you have aby Idea? Or is there any other Idea running "GO" without the upgrade Kit? Thanks a lot Jens Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted April 2, 2015 Report Share Posted April 2, 2015 Hi Jens, I'm not sure of an easy and reliable method that's going to be much cheaper than the £108 I don't think Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
