As far as i know there is no direct way to do this. If your SM only contains 1 scene you can load the SM you want to copy into the programmer and then record it to the memory. Or anoth method i have used in the past iis just play back the SM then record the memory (you will need smart tag enabled for this method to work)
  • 3 weeks later...
