Hi. If you mean the midi and switch interface then this is a separate pcb module that you can get from your local zero88 dealer. They should be able to fit it for you. But if you know what your doing i am sure you could do it yourself, however it may be worth checking if the DIY method will effect your warranty.
A list of distributers can be found here http://zero88.com/distributors/index.shtml
