PhilSpeck Posted February 10, 2015 Report Posted February 10, 2015 Hi, ORB XF crashed when clicking back in patch help screen. When restarted, using cue 0 results in no 0 intensity value appearing under channel, just blank. This is the same during cue stack playback. Has something just changed to hide this? Quote
Jon Hole Posted February 13, 2015 Report Posted February 13, 2015 Hi Phil, If you're in tracking mode, I'd only expect "0"s to appear if that data was in the cue. Cue 0 is a blackout, but as it's at the start of the stack, I wouldn't expect to see any "0"s, as no channels have to "change" to get to the blackout, if that makes any sense?! Quote Jon Hole linkedin.com/in/jonhole
PhilSpeck Posted February 13, 2015 Author Report Posted February 13, 2015 Makes sense I was in non-tracking when it crashed (and use in non-tracking all the time) The '0' values dissapeared for every cue that was there. I solved it by loading previous saved files - it just seamed strange... And on a very random side note, twice I've clicked on to the forum homepage link from a Google search and been taken to Adult Friend Finder or some similar name... could it be the forum end? :-/ Quote
