Chick3073 Posted February 5, 2015 Report Posted February 5, 2015 Hi I have recently purchased a solution desk and after setting it up and programming some memories I noticed that the first four preset faders are suddenly not controlling the lights. The lights still come on when the memory is output. Does anyone now what may of happened? Thanks Quote
Jon Hole Posted February 7, 2015 Report Posted February 7, 2015 Hi Chick3073, Do you know if the first four channels are addressed to DMX channels 1 - 4 on the dimmers? If you go into SETUP, do you see the following - specifically the first 4 lines that say: 1 [1] Dimmer 2 [2] Dimmer 3 [3] Dimmer 4 [4] Dimmer Quote Jon Hole linkedin.com/in/jonhole
keredyelesob Posted February 7, 2015 Report Posted February 7, 2015 I had a similar problem not so long ago i fixed the problem by re installing the software. But before you do i would follow jons advice above and also check the event monitor to see if the slider movements are actually seen by the desk. Quote
hafashah Posted March 3, 2015 Report Posted March 3, 2015 Have same problem different case, if you have dimer faders up , let’s say 1,2,3,4 to 50% and you are using these faders with a submaster they do not respond to the submaster , Is there a button to hit so you can control them? I’m trying to run live and recorded scenes . Quote
keredyelesob Posted March 3, 2015 Report Posted March 3, 2015 hi. i think this is because you have (in your example) 1,2,3,4 preset sliders set to 50%, this setting is stored in the programmer, (subs and que stack will no longer alter the values) if you hit the clear button to clear the programmer then the subs will start working again. you can change the desk settings to use HTP (setup, desk setup, behavior, preset mix mode) this way what ever method has the highest value will output. however bringing the sub down completely (in your example) will only return the outputs back to 50% as the preset sliders are then the highest at 50%. Quote
hafashah Posted March 4, 2015 Report Posted March 4, 2015 hi. i think this is because you have (in your example) 1,2,3,4 preset sliders set to 50%, this setting is stored in the programmer, (subs and que stack will no longer alter the values) if you hit the clear button to clear the programmer then the subs will start working again. you can change the desk settings to use HTP (setup, desk setup, behavior, preset mix mode) this way what ever method has the highest value will output. however bringing the sub down completely (in your example) will only return the outputs back to 50% as the preset sliders are then the highest at 50%. that is exactly what i'm looking for , thank you so much Quote
