JB97 Posted February 4, 2015 Report Posted February 4, 2015 Hi, On phantom jester, on one of my pc's all the dimmer channels were viewable, so I could see the. On the monitor. On my other pc, they are not there. How can I get them onto the monitor? Thanks, James. As I just posted this, I loaded phantom jester (using TL) and they are there, any ideas why it's intermittent? Quote
kgallen Posted February 4, 2015 Report Posted February 4, 2015 On the Phantom Frog there is a tickbox to show the monitor - is that the same on Phantom Jester? Quote
JB97 Posted February 4, 2015 Author Report Posted February 4, 2015 The monitor is shown, but the 200 dimmer channels are not shown (sometimes) Quote
Jon Hole Posted February 7, 2015 Report Posted February 7, 2015 Hiya, It's possible that they've been deleted in the showfile that's being loaded on the other computer (you can remove dimmers in SETUP, <DMX Patch> by using the syntax 49 THRU 200 @ CLEAR ). They may have also been deleted if phantom had been opened as a Jester ML24 or Jester ML48 previously, as it could be loading that showfile, rather than a new TL Xtra one. I'd suggest resetting the desk on Phantom and seeing if they reappear, or saving the showfile from phantom on the other computer, and then loading it onto this one. Alternatively, you could patch the additional dimmers to give you the 200 back again. Quote Jon Hole linkedin.com/in/jonhole
JB97 Posted February 8, 2015 Author Report Posted February 8, 2015 I don't need the full 200, as I only use the first 24, but thanks Quote
