Hi JB97,
Yes they are. You'll get the lowest common denominator of features, although there's not that much difference between the two consoles. The main thing is channel numbers - if you have 200 dimmer channels on the TL Xtra, only the first 24 will get transfered onto the JesterML24 (or first 48 on the ML48).
Fixtures, palettes, memories, submasters and soft patch will all work.
Jon Hole
Ah, that's brilliant, thanks Jon.
When I program I use phantom jester and prefer the exact control that the TL gives me through syntax, but I run shows on the ML. So I wasn't planning on programming more then the first 24 dimmers :)
