Hi, i would like to ask when will be added function "random" into effect window and is it possible to add also function "stragger"? ( I use that function in light factory of zero 88)
Thanks a lot, Petr
  • 4 months later...
  • 1 year later...
  • 1 year later...
Hi Both,
In ZerOS 7.9.3, due to be released in the coming weeks, we have added Quick Offset buttons along the top of the Effects Palette window. These are Forward and Backward per Fixture, Forward and Backward per Group, and Random Offset. Applying a "Mark On" or "Mark Off" effect and tapping "Random"  should create the effect you're after. You can then save that as an effect palette to quickly recall later.
