Ian_SDC Posted January 12, 2015 Report Share Posted January 12, 2015 I am using a mixture of Betapack 2, 3 and Chill's. I understand the law on a Betapack 2 is set to Linear by default. On the Betapack 3's i have left it as the default Normal. My question is should the Betapack 3's and the Chilli's also be set to Linear. Ian Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted January 12, 2015 Report Share Posted January 12, 2015 Hi Ian_SDC, It's completely up to you, but it would make sense for all your dimmers to be using the same Dimming Curve - unless you have a specific reason for not wanting that. Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
Ian_SDC Posted January 12, 2015 Author Report Share Posted January 12, 2015 Thanks Jon, I will change all to Linear after the Panto run has finished in case it changes dimmer levels. Ian Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted January 12, 2015 Report Share Posted January 12, 2015 in case it changes dimmer levels It will - so definitely wait :-) Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
