kgallen Posted December 14, 2014 Report Posted December 14, 2014 Hi Jon/all, Here is a fixture definition for the LEDJ Intense 9P10. It doesn't seem to be in the Rev28 fixture library. Home is White@Full Full parameter detail (colour lookup) is given for the Presets on Ch8 and the Programme for Ch7 for those of you with fancy desks. Attached IFT file for the 9 channel mode of this fixture. PDF manual is (just) too large to upload, but can be found here: https://prolight.co.uk/PRO/item.php?id=509865/ Regards, Kevin LEDJ_Intense_9P10.ift Quote
Jon Hole Posted December 17, 2014 Report Posted December 17, 2014 Thanks for that! I've added the other modes, and made a few little changes, so it's consistent with other fixtures in our library, and attached them all in this file. LEDJ_Intense_9P10.ift They'll also be included in the next fixture release. Thanks again Jon Quote Jon Hole Global Product Manager, Systems and Control
kgallen Posted December 17, 2014 Author Report Posted December 17, 2014 Nice This profile is also the same as used by the Showtec/Highlite Power Spot 9 Q5 (which is basically the same fixture with a different name on it...). Quote
Jon Hole Posted December 22, 2014 Report Posted December 22, 2014 Done, they'll be included in the next release :-) Quote Jon Hole Global Product Manager, Systems and Control
