kgallen Posted December 14, 2014 Report Posted December 14, 2014 Hi Jon/all, Here is a fixture definition for the LEDJ Intense 9P10. It doesn't seem to be in the Rev28 fixture library. Home is White@Full Full parameter detail (colour lookup) is given for the Presets on Ch8 and the Programme for Ch7 for those of you with fancy desks. Attached IFT file for the 9 channel mode of this fixture. PDF manual is (just) too large to upload, but can be found here: https://prolight.co.uk/PRO/item.php?id=509865/ Regards, Kevin LEDJ_Intense_9P10.ift Quote
Jon Hole Posted December 17, 2014 Report Posted December 17, 2014 Thanks for that! I've added the other modes, and made a few little changes, so it's consistent with other fixtures in our library, and attached them all in this file. LEDJ_Intense_9P10.ift They'll also be included in the next fixture release. Thanks again Jon Quote Jon Hole linkedin.com/in/jonhole
kgallen Posted December 17, 2014 Author Report Posted December 17, 2014 Nice This profile is also the same as used by the Showtec/Highlite Power Spot 9 Q5 (which is basically the same fixture with a different name on it...). Quote
Jon Hole Posted December 22, 2014 Report Posted December 22, 2014 Done, they'll be included in the next release :-) Quote Jon Hole linkedin.com/in/jonhole
