Hai,
Im new for this product. please kindly help me how can i program mabo frog for using as a 24ch dimmer console with manual operation faders. address 1 -24ch
Thanks
Dil
Hi Dil,
The Mambo Frog is not the most suited console for running 24 dimmer channels, but you can add dimmers onto the fixture channels if you wish.
The manual for the console can be found here, and it should give you all the information you need.
http://zero88.com/support/index.php?/Knowledgebase/List/Index/73/
Best regards
Jon
Jon Hole
