Hi Ben,
New windows always open on Desktop 1.
When you select or open a new window, you can then press "VIEW" on the front panel, and then on the 5 blank syntax keys (with the LCDs, above the numberpad) you can press "Size" which will rotate through all the possible positions and sizes. You can also choose "Select" to cycle through the open windows, "Screen" to change which screen it's displays on, and "Close" to close the selected window.
I hope this helps.
Best regards
Jon
