NickTaylor Posted November 20, 2014 Report Share Posted November 20, 2014 I cant believe I cant work this out. Spent ages last night trying to get the cuelist up on either monitor as the system booted with it not there. There must be a way of saving the show so it always starts up with say cuelist on one and outputs on another. Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted November 20, 2014 Report Share Posted November 20, 2014 Hi Nick, SHIFT + CUE will open the cue stack window. Which version of ZerOS are you running? In older versions of software, it will only store the View layout every 30 seconds or so, so if you make a change to the layout and then restart quickly, that change might not be stored. A quick and easy way to "force" a save is to go into SETUP and then come back out. Best regards Jon Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
