timthetutor Posted November 16, 2014 Report Posted November 16, 2014 how do you go into setup mode on the phantom jester so i can load in fixtures? Quote
Jon Hole Posted November 20, 2014 Report Posted November 20, 2014 Hi timthetutor, If you Right Click on any button, it's the equivalent of holding it down. So, you can right click the SHIFT button, and then click and hold the MODE button for around a second. Make sure you then right click the SHIFT button again, so you are no longer emulating holding it down, otherwise you'll get some strange results. Best regards Jon Quote Jon Hole Global Product Manager, Systems and Control
