Mikael Hellbratt Posted October 31, 2014 Report Posted October 31, 2014 Hello! I got a problem to load a ficture from adj vizi beam 5R into my fatfrog and leapfrog, I cant find this ficture in the Zero88 libary,i tryed to load vizi spot 5R but it dont work correct on brightness/dimmer, Anyone who can make some ficture or have some ideas to a solution on my problem? thnx/Micke Quote
mikeb Posted November 1, 2014 Report Posted November 1, 2014 Hiya The problem is that the Beam 5R has either 10 or 12 DMX channels with frost and no focus nor gobo indexing and the Spot 5R has either 11 or 13 DMX channels with focus and gobo indexing but no frost, and the dimmer function channels are not the same between fixture types either so the fixture files will be different. Please find attached fixture file for Vizi Beam 5R for both 10 and 12 DMX channels Regards Mike Vizi_Beam_5R.ift Quote
Mikael Hellbratt Posted November 2, 2014 Author Report Posted November 2, 2014 Ok I try this! Thanks a lot/ Micke Quote
