Dear Zero88 team,
Dear Forum members,
Tomorrow we are going to run a show using 18 Sunstrips (10 channel dimmers) and 12 LED Bars. (6 RGB segments each) as "pixel effects"
To be able to use the effect engine in easy way,I created a fixture file, for the sunstrips with only one brightness parameter. So at the end I have 180 single channel fixtures, LED Bars are patched as 12x6 RGB with virtual intensity.
Together with the other stuff (24 Moving Heads, Strobes, Dimmes etc.) there is no more space on the MFK.
So I patched the single channel fixtures to MFK, grouped them and moved them to the DMX-IN.
After that I added the rest.
Everything works as I expect it.
Until I load a show or restart the desk, then this message appears:
"Unable to Load Fixture File xyz [200], insufficient location"
Where xyz is the name of the fixture and [200] is the DMX-in channel
How can I get this run and why does this message not appear when patching the fixtures?
I attached the file I created so far.
Thanks already for your assistance.
Best regards
Christian
Desk: LeapFrog 48
ZerOS: 7.8.0 - latest version
Hallowwen14_07_woP.isf
