Enlarge sirius channels 24/48
Hi there, we have a Zero 88 Sirius 24/48 and would like to know if there is any way to expand the canal over 48 having, if not open any module or something similar I hope we podais help.
A greeting.
There never was a 'proper' way to expand the Sirius 24 or 48 to more channels and this was mostly a design limitation of the clever way the desk processing was done I think,
There is an option to connect two Sirius together using a slave cable BUT you can't run them both with DMX unless you use a DMX merge and it was only really intended to use with analogue controlled dimmers. You also have to record memories on both desks which give the 'look' you want to achieve - the desks don't communicate across the slave link except to synchronise 'Go' and cross fades.
If you really have a need to control more than 48 channels then you should be looking to upgrade to a Solution or a PC based solution.
