jrphs Posted September 24, 2014 Report Share Posted September 24, 2014 Hi I have been working on some large chases for a bunch of active suntrips which have taken me ages to make! I have made them in the cue stack but only want them on subs. I have copied them into subs but when I delete the memory with that chase in the cue stack it dissapears in the sub to. Is there anyway to copy them over to subs but not delete them from both places. I really dont want to have to make them again on the subs! Cheers Jack Quote Link to comment Share on other sites More sharing options...
iank99 Posted September 24, 2014 Report Share Posted September 24, 2014 Jack - you need to program the chase directly on the submaster (page 111 in the manual describes the process). Iif you copy from a memory to a sub, the software creates a referencing link. If you delete the memory - then the link points to nothing as you discovered.... Quote Ian Knight aka The Service Guy - www.serviceguy.co.uk Link to comment Share on other sites More sharing options...
ziglight Posted September 24, 2014 Report Share Posted September 24, 2014 here is what you can do : Load the memory into the Programmer (via the Load button) and then record this into a Submaster (via Record button) instead of just copy the reference of the memory into Subs don't forget to verify if all important parameters are tagged ! (and all other parameters are untagged !!) but when there are chases the thing is more complicated because you have to record any step one by one of the chase Quote Link to comment Share on other sites More sharing options...
jrphs Posted September 25, 2014 Author Report Share Posted September 25, 2014 Thanks for the responces, I'll make sure I go directly onto the subs next time! But loading the steps in to the programmer has also worked a treat! Thanks guys! Quote Link to comment Share on other sites More sharing options...
fensch Posted October 26, 2015 Report Share Posted October 26, 2015 Does the software also creates a reference link if i copy a memory to a submaster? And why do I can't copy a submaster chase to a memory? Quote Link to comment Share on other sites More sharing options...
