nerdsteve Posted September 20, 2014 Report Share Posted September 20, 2014 Hello, I need some help with this Aeson Zip Wash 3612 I'm stuck with. I know the channel list but I cant seem to create a working fixture for it.. The fixture works I have to program the show here in two days Quote Link to comment Share on other sites More sharing options...
nerdsteve Posted September 20, 2014 Author Report Share Posted September 20, 2014 FYI ch1 - Pan Scan 0~540* scan ch2 - tilt scan 0~280* Scan ch3 - Dimmer - 0~100% Dimmer ch4 - Strobe - 0~6: No Stobe, 7~65: Strobe Slow to Fast, 66~68: no stobe, 70~128: flash slow to fast, 129~132: no stobe, 133~191: Bright flash slow to fast, 192~195: No strobe, 196~255: dim flash slow to fast Ch5 - Red 0~100% brightness adjustment Ch6 - green 0~100% brightness adjustment Ch7 - Blue 0~100% brightness adjustment Ch8 - W (assuming white) - 0~100% brightness adjustment ch9 - Amber - 0~100% brightness adjustment ch10- X/Y Speed: 0-255 Slow to fast ch11 RGBA macro effect : 0-4 no effect, 5-20 8 color, 21-24 no fuction, 25-45 8 color change fast, 45-49 no function, 50-94: 8 color change slow, 95-99 no function, 100-149 RGBWA mix, 155-255 RGBW Acolor ch12 pan fine: 16 bit ch13 tilt fine: 16 bit ch14 function control : 0-127 non function 128-255 auto ch15 reset: 251-255 reset in 3 seconds ch16 dimmer speed: 0-255 fast to slow ch17 zoom function 0-255 Quote Link to comment Share on other sites More sharing options...
mikeb Posted September 20, 2014 Report Share Posted September 20, 2014 Hiya Can you confirm there is only 17 DMX channels for this fixture as from www://aesontech.com/led-moving-heads it says there are 18 DMX channels Oops - my error 3610 has 18 DMX channels :$ Try the attached ift and reply if any problems Many thanks Mike AesonZip3612.ift Quote Link to comment Share on other sites More sharing options...
nerdsteve Posted September 21, 2014 Author Report Share Posted September 21, 2014 Thanks man, its working... Again Thanks Quote Link to comment Share on other sites More sharing options...
