hello everybody
I have one more question about the color-codes in Zero-OS
some color-codes are explained in the manual other are not...
so for example in the Prgrammer and the Output-window
red parameters are tagged; yellow are not tagged...
key but what about the blue ones ?? or the (lite)green-ones ??
other question :
the color-codes in the Fixture-Level window are a real mystery for me
beside that the purple-ones seem to be coming from earlier tagged memory parameters (see the screenshot below).... but what about brown, lite-green, lite-blue etc ???
thanks for any help
Hi Ziglight,
Here are what the colours mean:
Red - programmer values (these aren't recorded anywhere yet, and will be removed when clear is pressed twice)
Yellow - being recalled from somewhere that isn't a cue (generally submasters, UDKs (on ORB) or a default value)
Blue - value from a cue / memory which has gone up since the previous cue (up towards the blue sky)
Green - value from a cue / memory which has gone down since the previous cue (down towards the green grass)
White - a "blocked" value where the channel's programmed at a value it's already at (shown as RED in fixture levels)
Purple - a tracked value from a previous cue
Yepp thank you very much for these informations...!! (these are very usefull to understand the progression of parameters in the stack and helps to improve edition...!!)
thanks ! :)
is there a chance to get this kind of "fixture-levels" also for Submasters in a future ZerOS ???
  • 1 month later...
