  • 1 month later...
Hi AlexSky,
Here are the fixture profiles you requested.
attachicon.gifBriteq.ift
Best regards
Jon
Hi Jon,
Whether it is possible to send the changed fixture profiles namely a color profile with CMY to RGB.
And I look for fixture for Acme iMove250S and iMove250W (8 and 16 Chn).
And also it is possible to ask to find you, briteq mega strobe 1500DMX, Jem AF-1, Antari Z-1200II and Antari HZ-400
Thanks in advance.
But how then to arrive if I have LED devices with RGB configuration, and head moving with CMY configuration? Constantly to switch?
Hi AlexSky,
ZerOS allows you to pick which colour space YOU want to work in, no matter if the fixture is CMY or RGB. The console will then convert from the colour space you choose to the colour space of the fixture automatically for you.
There is a request to offer direct control of both CMY or RGB, which is on the to-do list!
Jon
Jon Hole
