AlexSky Posted September 9, 2014 Report Posted September 9, 2014 Hi all!!! I look for fixture for Briteq LED MEGA BEAM and LED PIXEL BAR RGB Can be to eat alternative? I thank in advance. LED MEGA BEAM.pdf LED PIXEL BAR RGB.pdf Quote
Jon Hole Posted September 9, 2014 Report Posted September 9, 2014 Hi AlexSky, Here are the fixture profiles you requested. Briteq.ift Best regards Jon Quote Jon Hole linkedin.com/in/jonhole
AlexSky Posted November 3, 2014 Author Report Posted November 3, 2014 Hi AlexSky, Here are the fixture profiles you requested. Briteq.ift Best regards Jon Hi Jon, Whether it is possible to send the changed fixture profiles namely a color profile with CMY to RGB. And I look for fixture for Acme iMove250S and iMove250W (8 and 16 Chn). And also it is possible to ask to find you, briteq mega strobe 1500DMX, Jem AF-1, Antari Z-1200II and Antari HZ-400 Thanks in advance. Quote
mikeb Posted November 3, 2014 Report Posted November 3, 2014 Hiya RGB/CMY is not set in the fixture file but configurable on the console... http://zero88.com/forum/topic/5288-colour-edit-mode-cmy-or-rgb/ Mike Quote
AlexSky Posted November 4, 2014 Author Report Posted November 4, 2014 Hiya RGB/CMY is not set in the fixture file but configurable on the console... http://zero88.com/forum/topic/5288-colour-edit-mode-cmy-or-rgb/ Mike Mike thanks for help But how then to arrive if I have LED devices with RGB configuration, and head moving with CMY configuration? Constantly to switch? AlexSky Quote
Jon Hole Posted November 4, 2014 Report Posted November 4, 2014 But how then to arrive if I have LED devices with RGB configuration, and head moving with CMY configuration? Constantly to switch? Hi AlexSky, ZerOS allows you to pick which colour space YOU want to work in, no matter if the fixture is CMY or RGB. The console will then convert from the colour space you choose to the colour space of the fixture automatically for you. There is a request to offer direct control of both CMY or RGB, which is on the to-do list! Jon Quote Jon Hole linkedin.com/in/jonhole
