ziglight Posted August 28, 2014 Report Posted August 28, 2014 I use the "DMX IN" for various use and I am very happy with thisexample : to extend the Submaster-layer/pageexample : also to create some sort of master-dimmer for groups of fixtures (very useful !)unfortunately it seems that a fader can only control intensity of a fixture (or a group of fixtures) but that its not possible to control other parameters (like pan or tilt or color etc)... or say to control any choosen DMX channel via DMX-INis there a special reason that this is not available on the solution desk ??if the double control (fader + wheel) is available for intensity it should not be very difficult to get other accesses by fader too (via DMX-IN)?? Quote
Jon Hole Posted August 29, 2014 Report Posted August 29, 2014 Hi Ziglight, Other parameters won't always default to 0% (pan and tilt for example), so this becomes quite a bit less user friendly than intensity. The best way to do this would be to patch the fixtures in the normal way, and then record just Pan / Tilt / Colour onto a submaster (ensuring nothing else is 'tagged'). You can then change the "Submaster controls..." options within the submaster setup window to proportionally control that parameter. Best regards Jon Quote Jon Hole Global Product Manager, Systems and Control
ziglight Posted August 31, 2014 Author Report Posted August 31, 2014 You can then change the "Submaster controls..." options within the submaster setup window to proportionally control that parameter. okey thanks for these good suggestions ! Quote
