concerning Solution (OS 7.7 and 7.8) :
Hello
maybe I missed something or didn't look at the right spot...:
when programming a chase (memory or submaster) the default drive-modus is allways AUTO
I was looking around to change the default mode but couldn't find that feature...
=> most of my chases should be driven by BEAT-mode and I have to change the mode for every single chase I record.... I would like that every new chase record allwyas in BEAT- mode (or whatever else...) I would like to have a DEFAULT SETTING for that !
thanks for any help... :)
Hi Ziglight
I've added this as ZOS-5805. Currently, there is no way to change the default settings for a chase on the Solution (there is on the ORB, as chases work in a different way, so the issue is to bring those settings across to Solution).
Best regards
Jon
