Petr Posted August 2, 2014 Report Posted August 2, 2014 Hi All, I have the ORB-XF and I would like to ask about if you are going to add a random or shake fuction in the effect window in the next update? I miss that fuction quite enough and it would be very helpful to have it there. Thanks Peter Quote
Jon Hole Posted August 5, 2014 Report Posted August 5, 2014 Hi Peter, Thanks for the request, I have added it as ZOS-5804. Could you define what you would expect from the "Shake" functionality please? Quote Jon Hole linkedin.com/in/jonhole
Petr Posted August 14, 2014 Author Report Posted August 14, 2014 Thanks for the answer and is there ZOS-5804 somewhere there to download? Or ZOS-5804 will be added in the next update software 7.8 ? Thanks for answering Best regards Petr Hi, I use "shake function" at the light factory of zero88 which is similar random function. Thanks Quote
KWR88 Posted August 14, 2014 Report Posted August 14, 2014 Hi Peter, ZOS reference if an internally system we use to track feature requests and reported bugs. These are then considered for adding to future release of the desk OS. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com
