Calum Posted July 21, 2014 Report Share Posted July 21, 2014 Hello, I'm trying to programme submasters and memories but everytime I put them to 100%, it's resetting my fixtures to their home state, presumably because it "records what it sees" and when it's recorded, they're off. Basically, I want to control the fixtures COMPLETELY independently of submasters and memories - is this possible? Thanks Quote Link to comment Share on other sites More sharing options...
KWR88 Posted July 22, 2014 Report Share Posted July 22, 2014 First thing to check is what version of OS are you running on this desk? If it is 9.x or higher then check what program mode you are in. If you are in full change this to partial, then only the fixtures you select and alter an attribute on will be recorded. PM on the address below if you need any more help. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com Link to comment Share on other sites More sharing options...
Franck Posted July 23, 2014 Report Share Posted July 23, 2014 http://zero88.com/support/index.php?/de/Knowledgebase/Article/View/51/58/frog-range-operating-manual-issue-6-en Please read page 29 (Tagging Fixtures) Quote Link to comment Share on other sites More sharing options...
