jayartibee Posted June 24, 2014 Report Posted June 24, 2014 I've copied this over from Blue Room as there's not much response there. I am trying to control a JEM smoker using the auxiliary function of a new Jester 24/48. I have very little experience of DMX. The setup is this - the Jester is connected to a new Demux which has four analogue DIN cables to four analogue Betapacks.This is what I have done so far:The smoker is working fine using the test buttonJester DMX patch is ex-factory, I.e. ch 1-24 = DMX 1 -24The Zero88 Demux is with ex-factory settings.Connected the smoker to DMX Out on the DemuxIn Super User, I have gone into Aux setup, pressed Preset A Flash Button on Channel 24, and set it as an Aux Flash.On the JEM DMX controller I have set the dip switch to 000110000 (=24)Back in Run mode on the Jester, I have tried holding down <Shift> and Flash button 24 and nothing happens... UPDATE: Got the smoker working fine with the slider which of course gives smoke volume control. Button still doesn't work. I don't think I understand this Auxiliary business. Seems pointless - and doesn't work anyway. Quote
Jon Hole Posted June 25, 2014 Report Posted June 25, 2014 Hi jayartibee, Looks like this has been resolved on Blue Room, but if you have any further questions please don't hesitate to reply! Quote Jon Hole linkedin.com/in/jonhole
